De câteva zile Safari-ul meu se comporta uneori ciudat - refuză să-mi mai afișeze unele site-uri (macforum.ro, github.com, theverge.com) - în Chrome merg.
Uneori dupa 2-5 min se incarca.
“Safari can’t open the page “macforum.ro” becouse the server where this page is located isn’t responding”
Sierra - 10.12, Safari - 10.0 (12602.1.50.0.10)
Veci n’am mai avut astfel de probleme.
Ce am facut:
eliminat toate extensiile (AdBlock, Click to Flash)
Cateva mesaje din console (any:safari message type:error)
error 21:34:52.287363 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.287382 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.290311 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.290315 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.290265 +0300 sandboxd SandboxViolation: com.apple.Safari(3404) deny mach-lookup com.apple.lsd.mapdb [Duplicate; no report will be generated.]
error 21:34:52.290834 +0300 com.apple.Safari.SearchHelper NSURLSessionTask finished with error - code: -999
error 21:34:52.293908 +0300 sandboxd SandboxViolation: com.apple.Safari(3404) deny mach-lookup com.apple.lsd.mapdb [Duplicate; no report will be generated.]
error 21:34:52.293922 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.293938 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.297681 +0300 sandboxd SandboxViolation: com.apple.Safari(3404) deny mach-lookup com.apple.lsd.mapdb [Duplicate; no report will be generated.]
error 21:34:52.297712 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.297737 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.300790 +0300 sandboxd SandboxViolation: com.apple.Safari(3404) deny mach-lookup com.apple.lsd.mapdb [Duplicate; no report will be generated.]
error 21:34:52.300866 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.310285 +0300 sandboxd SandboxViolation: com.apple.Safari(3404) deny mach-lookup com.apple.lsd.mapdb [Duplicate; no report will be generated.]
error 21:34:52.310313 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.310320 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.310617 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.310634 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.380250 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.380257 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.380524 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
error 21:34:52.380538 +0300 com.apple.Safari.SearchHelper LaunchServices: Database mapping failed, process cannot lookup com.apple.lsd.mapdb port by name.
error 21:34:52.380855 +0300 com.apple.Safari.SearchHelper LaunchServices: disconnect event received for service <private>
Bootează în Safe Mode: dă restart și ține apăsat Shift imediat ce auzi sunetul de pornire până ce începe să booteze. Vezi dacă merge în Safe Mode, apoi dă un restart normal și încearcă din nou.
Bag sama că s-a bulit ceva în Safari. Șterge-i preferințele și ia-l de la zero.
Eu am spus aici că, de ex., Safari nu-mi poate afișa unele programe TV, pt asta trebuie să rulez alt browser, merge OK cu Roccat. Nu-mi încarcă Flash, deși l-am actualizat.
Foarte interesant este faptul că ieri nu mi-a mers și mie de cîteva ori macforum și încă vreo 2 site-uri. Dar era o problemă temporară și, la fel pe Chrome mergeau.
Eu am fost la părinți, unde am avut, deci alt ISP. Mai spuneam acum ceva timp că pe rețeaua respectivă (RDS Buzău) îmi mergeau Spotlight Suggestions, care nu-s disponibile în România!
Înapoi la București, am avut UPC și acum RDS, totul merge bine. Și nu mai am Spotlight Suggestions.
Ce voiam să zic: te-ai plimbat pe undeva zilele astea, te-ai conectat la altă rețea? Nu mă pricep, dar eu am pățit comportamente oarecum ciudate în situații de genul ăsta.
